Inventor General Discussion
Distinguished Contributor
nstalker
Message 1 of 6 (160 Views)
How to maintain material with pattern
160 Views, 5 Replies
09-26-2013 07:59 AM
I patterned features but the material did not come along for the ride.  I know I can change the material manually after the fact but I am making a parametric design so I want this to happen automatically.  How do I do this?
nstalker
Message 2 of 6 (155 Views)
Re: How to maintain material with pattern
09-26-2013 08:06 AM in reply to: nstalker
I have this same problem when creating a mirror.  I'm wondering if I can use iLogic to populate the material of new features
*Expert Elite*
JDMather
Message 3 of 6 (141 Views)
09-26-2013 08:17 AM in reply to: nstalker
It appears to me from image that should be pattern component rather than pattern feature.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Distinguished Mentor
ccarreiras
Message 4 of 6 (138 Views)
09-26-2013 08:19 AM in reply to: nstalker
Hi!
We are talking about multisolid part, right?
You are talking about body appearence or material?
Try to apply use "pattern a solid"  instead "pattern a feature". (the same for mirror).
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
nstalker
Message 5 of 6 (127 Views)
09-26-2013 08:32 AM in reply to: ccarreiras
Thanks for your responses.  Here's what happens when I try to pattern differently.  Screenshots 1 and 2 represent when I pattern the features.  I get the result that I want.  However, when I change the count of the rollers to be > what was entered before I have to manually change the material to red.
If I try to pattern the solid it does not produce the desired result.
ccarreiras
Message 6 of 6 (97 Views)
09-26-2013 10:48 AM in reply to: nstalker
Hi!
This little cilynder is associated to another solid, and the new elements get the color of the main solid.
Isolate this little cylinder as an independent solid and it will work well.
Regards.
CarlosC
Windows 7 64Bit
Announcements
Need installation help?
