I patterned features but the material did not come along for the ride. I know I can change the material manually after the fact but I am making a parametric design so I want this to happen automatically. How do I do this?
I have this same problem when creating a mirror. I'm wondering if I can use iLogic to populate the material of new features
It appears to me from image that should be pattern component rather than pattern feature.
Thanks for your responses. Here's what happens when I try to pattern differently. Screenshots 1 and 2 represent when I pattern the features. I get the result that I want. However, when I change the count of the rollers to be > what was entered before I have to manually change the material to red.
If I try to pattern the solid it does not produce the desired result.
