Inventor Forum
How to list design data of imported step file?
4 REPLIES 4
bl
260 Views, 4 Replies
When I import a step file from a supplier, I usually only can see a base1 or equivalent object in the browser.
Is there a way where I can list the design data (explode the base1) so I can be able to pick individual surfaces and save them as an Inventor part?.
4 REPLIES 4
JDMather
in reply to: bl
What is "design data"?
Can you attach the original file or at least a screen shot here?
Are you familiar with Feature Recognition?
Are you familiar with the Repair or Construction Environments?
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
bl
in reply to: JDMather
For excample, how can I list all the parts of this bearing instead of base1?
bl
in reply to: bl
Or how can retreive the flange from this step file and save it as a Inventor part?
JDMather
in reply to: bl
There are no parts - it is one solid.
You could Revolve-Cut the "bearing" from the flange and then add a standard bearing from Content Center.
