When I import a step file from a supplier, I usually only can see a base1 or equivalent object in the browser.
Is there a way where I can list the design data (explode the base1) so I can be able to pick individual surfaces and save them as an Inventor part?.
Solved by JDMather. Go to Solution.
What is "design data"?
Can you attach the original file or at least a screen shot here?
Are you familiar with Feature Recognition?
Are you familiar with the Repair or Construction Environments?
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mat
There are no parts - it is one solid.
You could Revolve-Cut the "bearing" from the flange and then add a standard bearing from Content Center.
