Hello:
I am new with inventor and would appreciate if you could help me go the right direction with a structure I am trying to build with extrusions of Cylindrical and Square cross section.
I am having a hard time making sure that when I join the members they do not just intersect one another...
I will need to do a stress analysis on this structure later, so I want to make sure my geometry will allow for that. But simply, how do I join, let's say, a square section member perpendicularly onto a cylindrical section member? I mean, without either intersecting a member into the other or leaving a gap of space between their surfaces? The joint surfaces will later be spot welded and would of course need to mate. So for instance, the end of a square extrusion would have to end up with a radious instead of remaining flat ended in order for it to mate onto the curved radial surface length of the cylindrical extrusion.
I am hoping I am making myself clear. Sorry for the rambling about this...
Your help will be greatly appreciated.
Thanks very much.
