Inventor Forum
How to import a CATIA CATPart into Inventor and keep the CATIA tree?
7 REPLIES 7
Message 1 of 8
genscripter
4124 Views, 7 Replies
How do I import a CATPart into Inventor and keep all the geometrical sets?  I can import a CATPart ok, but it's seen as one big composite object, even though there are about a thousand surfaces in the CATPart.
0001D LLC. Where Design, Genetics, and Technology Overlap www.0001design.com
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: genscripter
You cannot maintain feature history trees going between CAD programs.
You might be able to run Feature Recognition on some of the features you need to change (was the entire part modeled incorrectly?).
If you are on subscription - you can download the Feature Recognition tool from the Autodesk App Exchange.
Message 3 of 8
genscripter
in reply to: JDMather
It's not necessarily the "History" tree that I want.  It's the specification tree from CATIA that I want, containing Geometrical Sets, Bodies, and Ordered Geometrical Sets.
Message 4 of 8
JDMather
Only the base geometry is translated.
Message 5 of 8
Hi genscripter,
Thanks for reporting!
The CATIA tree about Geometry Set nodes cannot be imported into Inventor, you can try to set import option CreateSurfaceAs=IndividualSurfaceBodies then thousand surfaces should be imported individually instead of a big composite.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 6 of 8
Where do you find that setting?  I checked the "import" options, and it only allows me to import as one big component from the pulldown.
Message 7 of 8
JDMather
You could send to Construction (or Repair) Environment.
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Message 8 of 8
Hi genscripter, I captured a screenshot for your reference, see attached. Regards,
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
