Inventor Forum
how to hide yellow lines that are originated from features
9 REPLIES 9
Message 1 of 10
hugolopessilva
6613 Views, 9 Replies
When I perform a feature on inventor, some yellow lines appear. How can I delete them, or change the view in order to hide them?
regards,
Hugo
9 REPLIES 9
Message 2 of 10
thaddeus
in reply to: hugolopessilva
Can you post a screen shot?
Message 3 of 10
JDMather
Are these projected sketch edges?
Are these surface edges?
Are the solid body edges?
Quite obviously more information is needed.
Post screen capture as suggested - or better yet, the ipt file.
Message 4 of 10
hugolopessilva
in reply to: JDMather
They are originated from extruded cut, which is a solid feature. I´m posting the ipt file in attachment.
Message 5 of 10
JDMather
I'm suspecting all you need to do is turn off the visibility of the sketches.
Not sure I understand the problem?
I'm having trouble understanding your design intent for the entire feature tree?
Message 6 of 10
hugolopessilva
Thanks for your help. How can I turn off the visibility of the sketches?
regards,
Hugo
Message 7 of 10
JDMather
Right click on them in the browser.
Message 8 of 10
hugolopessilva
It works. Thanks a lot!
regards,
hugo
Message 9 of 10
scorpion52
Another way, just in case anyone wants to know, it to right click on the line . . . edit sketch  . . . highlight and delete them one by one. You might have to do this a number of times, depending how many sketches you have made.
Oh, yes . . . . save the file as you go . . . Inventor doesn't like to do too much at one time ; )
Message 10 of 10
JDMather
in reply to: scorpion52
@scorpion52 wrote:
.... and delete them one by one. You might have to do this a number of times, depending how many sketches you have made.
Crossing window selection is much faster.
And turning off AutoProjection in Application Options avoids the problem alltogether
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
