Inventor Forum
How to have construction lines already drawn when starting new sketch?
9 REPLIES 9
Message 1 of 10
hhls11
1907 Views, 9 Replies
Hi all,
I'm wanting to have vertical and horizontal construction lines already created whenever I start a sketch so that I can set symmetric constraints to the part I'm drawing up. At the moment, I have to draw both lines every time and constrain them to the center point. It would be much easier if it was already there when I started so I can start on the sketch right away. Is there a way to do this? I've included a photo of what I'd like to do. Thanks in advance for your help!
Inventor Professional 2021
Intel Core i7-9700K @ 3.60Ghz
16GB DDR4 RAM
NVIDIA GeForce RTX 2060 Super GPU
Windows 10 Professional 64-bit
9 REPLIES 9
Message 2 of 10
jletcher
in reply to: hhls11
Well there is no photo but why would you draw lines? just use constraints Vertical and horizontal to the center orgin.
You can have it auto project the orgin center..
Message 3 of 10
in reply to: hhls11
Try projecting the x & y axis into the sketch (assuming you are on the xy plane).
Message 4 of 10
hhls11
in reply to: jletcher
I do already have the origin projected, but using the horizontal and vertical constraints won't make my sketch symmetic about the origin axis. That's my main objective here...
@john: I tried to project the axis into the sketch, but it didn't work
16GB DDR4 RAM
Message 5 of 10
in reply to: hhls11
Turn on construcion, click project geometry, then click X Axis and Y Axis in the browser, then OK.
Message 6 of 10
jletcher
in reply to: hhls11
That funny it works for me all the time.....................
Maybe you are doing to much on base sketch.....
Message 7 of 10
Curtis_Waguespack
in reply to: hhls11
Hi hhls11,
I'm not aware of setting to do this, but you could use this iLogic rule to quickly add the projected line as cosntruction lines to any sketch that needs them.
If Typeof ThisApplication.ActiveEditObject Is Sketch Then
'Do nothing
Else
MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
Return
End If
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oSelectSet As SelectSet
oSelectSet = oPartDoc.SelectSet
oSelectSet.Clear
'turn on construction line
ThisApplication.CommandManager.ControlDefinitions.Item("SketchConstructionCmd").Execute
'look at the workplane collection
For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
'find origin planes only
If oWorkPlane.IsCoordinateSystemElement = True Then
oSelectSet.Select(oWorkPlane)
End If
Next
'Project Geometry
ThisApplication.CommandManager.ControlDefinitions.Item("AppProjectGeometryWrapperCmd").Execute
'Cancels active command
ThisApplication.CommandManager.StopActiveCommand
'turn off construction line
http://inventortrenches.blogspot.com/2012/01/creating-basic-ilogic-rule-with-event.html
I hope this helps.
Curtis
Message 8 of 10
PhilSaw
in reply to: hhls11
In sketch mode, select construction lines for linetype, then project geometry either from the relavent workplanes or axis.
This is what I would do, except without turning on construction lines.
Please click "Accept as Solution" if this response answers your question.
Autodesk Inventor Professional 2012
Windows 7 Professional, 64-bit (Service Pack 1)
Intel(R) Core(TM i7-2600 CPU, Quadro 2000 graphics card, 8G RAM
Message 9 of 10
hhls11
This method seems to work fine. Thanks for your help.
16GB DDR4 RAM
Message 10 of 10
in reply to: hhls11
If you often start your sketches like this, you may want to save this as a template.
