Is there a way to get that long tube and that rectangular part all around that middle circle.
Open this picture. In the end it would end up looking somthing like that lamp shade. I got one part down so is there a way to get a bunch of those around instead of redrawing it?
I am using inventor 2010.
Thank you.
Yes. Circular pattern.
It might also be pointed out that you're doing a WHOLE lot of work to get to where you already are. There should be no more than 4 extrusions and one work plane, or 3 extrusions and 2 work planes. You should also be fully constraining your sketch geometry.
Have you run through the tutorials?
Looks like a simple feat. Create the long rod and the arced panel and them do a polar array around the center.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi treasure1100,
As graemev pointed out, your model can be made more robust and efficent, but you've done pretty well for getting started. Attached is a quick example of your model that might help you see how to make it more effeicently.
Don't forget to keep your sketches simple and fully constrained / dimensioned:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
