Inventor Forum
how to get the ends of the coil to meet each end
16 REPLIES 16
Message 1 of 17
James__S
1128 Views, 16 Replies
Hi
Not sure i have used correct modelling technique here but can the ends of the Coil join each section which looks natural.I have not been able to get the ends to smoothly join with the coil feature
Best Regards
James
16 REPLIES 16
Message 2 of 17
JoAnn_Hogan
in reply to: James__S
Your part gives me errors when I try to open it up. Please suppress the feature thats got the error and resend the file so I could look at the part
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 17
James__S
in reply to: JoAnn_Hogan
Thanking you...i rolled up the EOP.....please let me know if this still does not work
Message 4 of 17
JoAnn_Hogan
Are you looking for something like this?
Jo - Ann
Message 5 of 17
JoAnn_Hogan
Sorry I forgot the Attachment. I moved the EOP up
Jo - Ann
Message 6 of 17
James__S
Hi
Yes thank you close.Can the Coil where they start at each end run along the edge.There is a sketch in black which shows how each end starts.Not have the ends of the coil revolving into towards the centre at the start
Message 7 of 17
JoAnn_Hogan
This is the closest I could get it.
Jo - Ann
Message 8 of 17
James__S
thank you
It would be difficult to get it closer to the edge...thank you for help
Message 9 of 17
graemev
How about exactly on the edge?  Take a good look at the sketch for the coil, the last extrusion, and the model parameters to see how to get an exact fit.
Message 10 of 17
James__S
Thanks...can the start of the coil also run on the edge...not sure if possible but i was not successful
Message 11 of 17
graemev
Quite probably, but that's getting a bit beyond me.
J. D. Mather may be a better resource for surface modelling like that.
Message 12 of 17
James__S
in reply to: graemev
Surface modelling will be needed to create this shape.I too unfortunately don`t know how to surface model....maybe the shape is not possible
Cheers
Message 13 of 17
JDMather
James__S wrote:..
Cheers
Wrong attitude to approach the problem.
If you had a block of clay in front of you - could you sculpt the geometry?
Message 14 of 17
JDMather
in reply to: JDMather
The second question would be, "How will you manufacture the geometry if you can sculpt it?"
Message 15 of 17
James__S
I would think a mold for this plastic part.
Message 16 of 17
VdVeek
You can use a Lofted "Revolve" for the last part where you start with a round matching the end of the coil and end with an elipse with a width of the coil and a height of almost zero. See the attached ipt for an example.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 17 of 17
James__S
Thanks Rob
Good example
Cheers
