Inventor Forum
How to get rid off the edge lines??
3 REPLIES 3
Major Ton
586 Views, 3 Replies
Hi all,
After creating a complete assembly, edge lines (I don't know the right term for that) are still visible. How can I make them invisible so that my creation will look like one solid object?
Gr.Sven
3 REPLIES 3
in reply to: Major Ton
Tools -> Application Options -> Display tab
on right hand side (Shaded Display Modes) turn off "Silhouettes" and "Edge
Display" under Active
wrote in message news:5007913@discussion.autodesk.com...
Hi all,
Gr.Sven
If you're referring to the Assembly environment go to the main menu --> Tools --> App Ops ... --> Display (tab) --> Shaded Display
Modes (panel) and de-select everything under Enabled, Active & Background.
If you're in the DM you need to select (use a Window or Crossing Window) the lines, RMB and de-select Visible.
HTH
Duncan
"Humour ... is one man shouting gibberish in the face of authority, and proving by fabricated insanity that nothing could be as mad
as what passes for ordinary living."
(Terence 'Spike' Milligan K.B.E., 1918-2002)
www.autodesk.co.uk/inventorjobs
Hi all,
Gr.Sven
Major Ton
Great! Thank you!
"Tools -> Application Options -> Display tab" I've been there many times, but never looked closely enough I guess...
Thanks again
