I am using the stress analysis FEA portion of Inventor on a shaft of changing diameters. While I have gotten the simulation to run and produce what seems to be good results (max deflection of .04 mm on a 375 mm shaft with an average diameter of 35mm), I need to find the slope of deflection at both of the bearings (represented her by pin constraints on portions of the shaft). Does anyone know if this is even possible with inventor?
Thanks for your help.
Dan
