Inventor Forum
how to find sub-assy that needs updating
6 REPLIES 6
slphantom
486 Views, 6 Replies
I have a large automated machine that has a lot of sub-assys in it. the update icon is showing and will not update the assembly when I pick on it. This usually means one of the sub-assys needs to be updated. is there a quick way to determine which one it is? Inventor 2012
thanks
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
6 REPLIES 6
stevec781
in reply to: slphantom
I sometimes get this and I also get frame generator members that dont update.  I find the only way to be sure everything has been updated is to close the model and open the top level asm.
slphantom
yeah I have gone thru all my top level sub assemblies and can't find it.
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
bobvdd
Scott,
This question comes up from time to time. That is why I decided to write a small VBA project for it.
Unzip attached file to any folder.
Start the VBA editor and do a FIle > Load project and select the file callled Outofdatedetection.ivb.
When you open an assembly that brings up the update dialog, run the macro called Show_Out_of_date_components(). Hopefully it will give you some extra information on why you got the update dialog. The button on the right serves another purpose (it lists the files that have been modified  and that you would normally see listed in a save operation).
Cheers.
Bob
Bob Van der Donck
Principal UX designer DMG group
slphantom
in reply to: bobvdd
works great thanks. i have a list of the probable sources but can't find it yet. this helps a lot thank you.
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
slphantom
in reply to: bobvdd
I found out what the problem was, i don't get it, but i found it. there was a prox. switch that was mated to the face of one the the plates in my sub-assembly. just one constraint, a mate, that offset the plate to the switch. weird.
thanks
Scott
win 11 64 bit
Inventor Pro 2023
Space Explorer
I've found that sometimes adaptivity stops regeneration.
