I had posted a picture with the original message, but when I open it I don;t
see it I will try here with a different format.
"David Bellis" wrote in message
news:4898997@discussion.autodesk.com...
I have an assembly I want to insert/create a brace into.
The difficulty is this. I have a vertical face 2" x 2" steel tube and I want
to create another 2" x 2" brace from the face of that up at about 50-60
degrees to the bottom of a table surface.. (more or less) I will add more
later when I figure out how to create this feature.
When I try to make a work plane at the 50 degrees and mate it to the
vertical surface, make a sketch of a 2" x 2" on it then try to extrude it
from-to, the only optio
n to extrude is the TAKE AWAY icon, not the create a
solid extrusion icon.
I could probably redraw the thing on autocad to figure out the exact
dimensions required, but I would much rather have INVENTOR create it for m
