Inventor Forum
How to export 3D points to excel?
16 REPLIES 16
Message 1 of 17
7304 Views, 16 Replies
Please help.
Thanks in advance.
16 REPLIES 16
Message 2 of 17
Hochenauer
Open the VBA Editor from Inventor/Tools.
Inside the Vba editor, select Tools-> References from the menu.
Check the Microsoft Excel Object Library
Sub ExportWorkpoints()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Dim oWorkpoints As WorkPoints
    Dim oWP As WorkPoint
    Dim oP As Point
    'get all workpoints in this part
    Set oWorkpoints = oDef.WorkPoints
    'create a new excel workbook
    Dim oBook As Excel.Workbook
    Set oBook = Excel.Workbooks.Add()
    Dim oSheet As Excel.WorkSheet
    Set oSheet = oBook.ActiveSheet
    Dim nRow As Integer
    nRow = 1
    'write the coordinates into separate columns, one workpoint each row
    For Each oWP In oWorkpoints
        Set oP = oWP.Point
        oSheet.Cells(nRow, 1) = oP.X
        oSheet.Cells(nRow, 2) = oP.Y
        oSheet.Cells(nRow, 3) = oP.Z
        nRow = nRow + 1
    Next
    oBook.SaveAs ("c:\test.xls")
End Sub
Hope this helps,
Gerald
Gerald Hochenauer(gerald.hochenauer@autodesk.com)
Inventor Principal Software Engineer
Manufacturing Group
Autodesk, Inc.
Gerald Hochenauer
Senior Principal Engineer, Inventor
Autodesk, Inc.
Message 3 of 17
Id like to know more about this if possible? Could you give more detailed instructions please? Ive opened the VBA editor, checked excel object library but when i enter the text in a new module and try to run it, it comes up with an error.
Thanks, Dan
Message 4 of 17
Could anyone please give me some help with this as i'm completely stuck.
Thanks in advance.
Message 5 of 17
Hochenauer
Dan,
I need some info on the error you are seeing in order to be able to help. What line of the code? What's the error message?
Gerald
Gerald Hochenauer
Autodesk, Inc.
Message 6 of 17
in reply to: Hochenauer
Gerald,
It says "Compile error: User-defined type not defined"
If i click "ok" it then highlights the line of code "oBook As Excel.Workbook"
Does that help?
Im creating the module under "Document Project"
Thanks.
Message 7 of 17
Sorry, that was the wrong one actually! Id forgotten to check excel object library.
With that checked it now reads "run-time error '13': Type mismatch" If i click debug, it highlights the line "Set oDoc = ThisApplication.ActiveDocument"
Any ideas?
Thanks, Dan
Message 8 of 17
Hochenauer
Are you running this from within a part document?
Gerald Hochenauer
Autodesk, Inc.
Message 9 of 17
It's an assembly, but only with <20 parts. Will it only work on a part document then?
Message 10 of 17
Hochenauer
The example I wrote is for a single part document - it is a generic example that takes workpoints within this part and exports their locations.
as opposed to
 Dim oDoc As AssemblyDocument
In order to extend the sample to assemblies, you'd have to iterate over the assembly component Definition structure(Assemblies can contain sub assemblies,....) .
You'd need to know about Component Occurrences and transformations in order to get all the points to show up at the assembled locations.
Unfortunately I can't spare the time to write it - I need to wrap up things before leaving on a 3 week business trip. Maybe somebody else can pick it up or you get some training. It is quite a good example to learn how programming Inventor with VBA works.
Gerald Hochenauer
Gerald Hochenauer
Autodesk, Inc.
Message 11 of 17
You could do a Derive Part and choose the assembly. Then you could run the code on the Derived Part.
Mike
Message 12 of 17
I have tried to apply this module to single part document however an error comes up:
Run Time Error 91
Object variable or with block variable not set
and after debug this line is highlighted: Set oDef = oDoc.ComponentDefinition
Could you please explain what i'm doing wrong.
Message 13 of 17
Hochenauer
From your description it sounds like oDoc has not been assigned.
Please make sure that oDoc is spelled the same everywhere. It might be case sensitive if 'Option Exlicit' is not stated on top of the page.
Gerald
Gerald Hochenauer
Autodesk, Inc.
Message 14 of 17
Dear Sir,
I am now getting another error stating:
Upon debugging the following line is highlighted:
Thank you for you support,
Kyra
Message 15 of 17
Hochenauer
The save operation fails for probably one of the reasons outlined in the error dialog message.
Please make sure that the .xls file does not exist prior to running the vba macro, and manually delete it before each new run. Close excel as well. Alternatively you can extend the code to handle such cases - it should be possible with some VBA training.
kind regards,
Gerald
Gerald Hochenauer
Autodesk, Inc.
Message 16 of 17
Problem Solved, Thanks for your support.
Message 17 of 17
Cadguy_2014
Nice
