I just upgraded from 2012 to 2014 Professional, and on my ribbon all of the tools appear to have been grouped/minimized, making it a pain just to click on even the most commonly-used tools.
For example, when I am in the Sketch tab, all of the tools are grouped and hidden under a cateogry, such as the "Draw" category, and I need to first click on Draw to be able to select a Line or Rect or whatnot.
How can I expand these out so that all tools are displayed for a given tab?
Solved by jalger. Go to Solution.
See the white Arrow beside the rest of the tabs (beside Sketch in your screenshot).
Click the arrow and it Cycles through 4 view options:
Full >Images (what you're Currently on) > Text > Hidden (you have to click on it to see the ribbon)
In your case you should need 3 clicks, (move to text, hidden and back to full)
I hope this helps,
James
