For some reason, I am unable to use the iMate feature of Autodesk Inventor. I am unable to select iMates on existing parts to assemble them with other parts. I have followed all the instructions for using iMate features, but I always run into trouble because, even though I did indeed enable iMate glyph visibility, and I did do all the other stuff they said, when I click on the iMate glyph, nothing happens. It is as if they weren't even there at all. Selecting the iMates from the project browser on the left doesn't work either; while I am able to select the features, I am unable to move the parts or select any other iMates, except as a group selection, which doesn't let me do anything, either.
Hi anson,
Could you provide your dataset(as ZIP file) so I can try it on my machine?
What is your Inventor's version? I can debug inventor code but I have to know exactly which version you're using.
Attach your ZIP into this message if possible.
Thank you,
Robert
