How to emboss scale on the cylinder? Please see the file attached. The arrow is the portion I want to created in my part file.
Solved by rdyson. Go to Solution.
Solved by JDMather. Go to Solution.
Dear Sir
Thanks for your reply. However I cannot open your file. The error message is "Error in reading Rse Stream". I am using IV2011.
I deleted the minus 0.0001, there is no problem
However when I deleted the EMBOSS feature and tried to use the sketch to rebuild the emboss, I have to select the text and small retangulars one by one. I cannot select the whole sketch from the browser to create emboss. Is that the right way?
@lis_wang wrote:I deleted the minus 0.0001, there is no problem
Then try Rebuild All.
That was a bit more of a problem than I expected, or maybe I just made it so.
