Hello everybody,
How do I change the content in the 'information box' on the bottom right-hand corner of drawings?
Would be much appreciated if anyone can answer.
Thank you
Solved by Nicolas.Bourquin. Go to Solution.
Please expand? iProperties or making own title block does not replace the current one.
Dear Rashpal,
To fill up the different fields of a Title Block, there are different ways depending how the Titleblock is designed.
The Texts values can come for examples from the drawing iproperties, from the 3D model iproperties or from prompted values...
Tip : if you would like to know which iproperty field concerns which information in the titleblock => select the titleblock in the browser => right mouse button (RMB) => edit definition => verify 1) the type (drawing iproperties, model iproperties, prompted value,...) 2) the field of the iproperty of the corresponding type. (See the picture 1 attached)
According to your picture, it seems you are using the default ISO titleblock.
(the ISO tiltleblock fields are all filled with the values from drawing iproperties).
See the picture 2 attached presenting you the origin of the different fields.
Here is an interesting link on this subject:
I hope that will help.
Best Regards
