Inventor Forum
How to edit information box
5 REPLIES 5
1576 Views, 5 Replies
Hello everybody,
How do I change the content in the 'information box' on the bottom right-hand corner of drawings?
Would be much appreciated if anyone can answer.
Thank you
5 REPLIES 5
mdavis22569
In the Iproperties. or make your own Title block
Mike Davis
in reply to: mdavis22569
Please expand? iProperties or making own title block does not replace the current one.
mdavis22569
Find the line you'd like to edit. For example: Title. Title can be found by going into the iproperties and going to the summary tab and populating the Title line. It would be the same for any other like you'd like to populate. Of you can make a sketch and put your own text in and copy and paste it from drawing to drawing and edit it (this is a horrible way, but quick)
Mike Davis
Nicolas.Bourquin
Dear Rashpal,
To fill up the different fields of a Title Block, there are different ways depending how the Titleblock is designed.
The Texts values can come for examples from the drawing iproperties, from the 3D model iproperties or from prompted values...
Tip : if you would like to know which iproperty field concerns which information in the titleblock => select the titleblock in the browser => right mouse button (RMB) => edit definition => verify 1) the type (drawing iproperties, model iproperties, prompted value,...) 2) the field of the iproperty of the corresponding type. (See the picture 1 attached)
According to your picture, it seems you are using the default ISO titleblock.
(the ISO tiltleblock fields are all filled with the values from drawing iproperties).
See the picture 2 attached presenting you the origin of the different fields.
Here is an interesting link on this subject:
I hope that will help.
Best Regards
Nicolas Bourquin
in reply to: Nicolas.Bourquin
Nicolas,
That was extremely helpful. Thank you for the help!
