Inventor General Discussion
2,126 Kudos
Post 11 of 14
Re: How to draw segment elbow 90 degrees and create Flat Pattern ?
02-01-2013 05:01 AM in reply to: haisin.rusli
What are you trying to trim (can you post screen capture of trim from the example file)?
You can use a simple line on a 2D sketch to trim or use the line to create a workplane.
More information is needed on what you are trying to do.
Are you trying to model the perfect parts with no intersection?
Will you be making these parts in-house or sending out to a vendor for manufacture?
What is the manufacturing tolerance?
How will the individual gores be assembled?
Sheet metal like this usually has liberal tolerances and the slight intersections in this technique might not be of enough significance to worry about.  Check with the fabricator out on the shop floor to see if the solution will be good enough.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
8 Kudos
Post 12 of 14
02-03-2013 07:53 PM in reply to: haisin.rusli
@Sam B : I've  thicken them individually, but how to make separate solids? ( how's the next step ? )
Please see the attachment.
@JDMather : I just want to do what TheCADWhisperer did. ( not making perfect parts with no intersection )..:smileyhappy:
Best Regards,
Haisin Rusli
*Pro
284 Kudos
Post 13 of 14
02-04-2013 04:16 AM in reply to: haisin.rusli
Use the New Solid button in the Thicken/Offset dialog box.  You can go back and edit your Thicken features as shown:
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Active Contributor
8 Kudos
Post 14 of 14
02-05-2013 06:46 PM in reply to: haisin.rusli
@Sam B : I've  did it myself, thank you for the explanation! :smileyvery-happy:
Best Regards,
Haisin Rusli
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here.
