Inventor General Discussion
Active Member
psarkar70
Message 1 of 15 (1,405 Views)
How to draw a hemisphere on cylindrical curved surface
1405 Views, 14 Replies
10-15-2009 02:15 AM
Please let me know how to draw a hemisphere on cylindrical curved surface. I tried using work plane (tangent plane to the curved surface), but it didn't worked. I am not able to join the flat hemispherical surface with the curved cylindrical surface. Please help me.
*Expert Elite*
harco
Message 2 of 15 (1,405 Views)
Re: How to draw a hemisphere on cylindrical curved surface
10-15-2009 04:36 AM in reply to: psarkar70
see attached
*Pro
sbixler
Message 3 of 15 (1,405 Views)
10-15-2009 09:40 AM in reply to: psarkar70
Not sure if I've understood exactly what you're trying to do, but here's my attempt (Inventor 2009 format)
Sam
Active Member
psarkar70
Message 4 of 15 (1,405 Views)
11-09-2009 07:20 AM in reply to: psarkar70
Thanks , this is exactly what I wanted. Sorry for being late. I had given up hope. Can you please let me know how you did it. As the cylinder is having a curved surface and how to put a hemisphere on it which is having a flat surface. I have noticed the work plane in your drawing is not parallel to any of 3 planes (namely XY , XZ or YZ).
Thanks again.
Partha
*Expert Elite*
JDMather
Message 5 of 15 (1,405 Views)
11-09-2009 07:34 AM in reply to: psarkar70
If you edit the sketches you will see a line used to create the user Workplane.
Check this one - maybe it will be easier to understand.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
*Expert Elite*
JDMather
Message 6 of 15 (1,405 Views)
11-09-2009 07:39 AM in reply to: psarkar70
Your method?
Active Member
psarkar70
Message 7 of 15 (1,405 Views)
11-09-2009 07:44 AM in reply to: psarkar70
Can you please save it in Autodesk 2009 format . I can't open it, I have Autodesk Inventor 2009.
Thanks.
Partha Edited by: psarkar70 on Nov 9, 2009 3:44 PM
Active Member
psarkar70
Message 8 of 15 (1,405 Views)
11-10-2009 01:42 AM in reply to: psarkar70
Hello jmather
Can you please save the files as Autodesk 2009 format. I can't open these files, I have Autodesk 2009.
*Expert Elite*
JDMather
Message 9 of 15 (1,405 Views)
11-10-2009 05:01 AM in reply to: psarkar70
Attach your file here and I will show you how to fix the geometry.
Active Member
psarkar70
Message 10 of 15 (1,405 Views)
11-10-2009 05:14 AM in reply to: psarkar70
Hi jmather
Please find the attached file (cyl.ipt -- Autodesk 2009 format). I tried to draw a hemisphere on a cylindrical surface, but unable to do so as cylinder has a curved surface and hemisphere has a flat surface. Can't join these 2 parts together.
Partha Edited by: psarkar70 on Nov 10, 2009 1:16 PM
Announcements
Need installation help?
