Inventor Forum
How to draw a hemisphere on cylindrical curved surface
14 REPLIES 14
Message 1 of 15
psarkar70
2509 Views, 14 Replies
Please let me know how to draw a hemisphere on cylindrical curved surface. I tried using work plane (tangent plane to the curved surface), but it didn't worked. I am not able to join the flat hemispherical surface with the curved cylindrical surface. Please help me.
14 REPLIES 14
Message 2 of 15
harco
in reply to: psarkar70
see attached
Message 3 of 15
SBix26
Not sure if I've understood exactly what you're trying to do, but here's my attempt (Inventor 2009 format)
Sam
Message 4 of 15
psarkar70
Thanks , this is exactly what I wanted. Sorry for being late. I had given up hope. Can you please let me know how you did it. As the cylinder is having a curved surface and how to put a hemisphere on it which is having a flat surface. I have noticed the work plane in your drawing is not parallel to any of 3 planes (namely XY , XZ or YZ).
Thanks again.
Partha
Message 5 of 15
JDMather
If you edit the sketches you will see a line used to create the user Workplane.
Check this one - maybe it will be easier to understand.
The CADWhisperer YouTube Channel
Message 6 of 15
JDMather
Your method?
Message 7 of 15
psarkar70
Can you please save it in Autodesk 2009 format . I can't open it, I have Autodesk Inventor 2009.
Thanks.
Partha Edited by: psarkar70 on Nov 9, 2009 3:44 PM
Message 8 of 15
psarkar70
Hello jmather
Can you please save the files as Autodesk 2009 format. I can't open these files, I have Autodesk 2009.
Message 9 of 15
JDMather
Attach your file here and I will show you how to fix the geometry.
Message 10 of 15
psarkar70
Hi jmather
Please find the attached file (cyl.ipt -- Autodesk 2009 format). I tried to draw a hemisphere on a cylindrical surface, but unable to do so as cylinder has a curved surface and hemisphere has a flat surface. Can't join these 2 parts together.
Partha Edited by: psarkar70 on Nov 10, 2009 1:16 PM
Message 11 of 15
psarkar70
Sorry, please find the file.
Message 12 of 15
psarkar70
Please find the attached file.
Message 13 of 15
JDMather
First thing I noticed is that Sketch1 is not constrained. Why place a circle at the origin but not have Inventor automatically constrain to the origin?
You might want to go through this document.
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mather.pdf
What if you changed the Revolve feature to 360° instead of 180°?
If that solution doesn't work (you actually want partial cylindrical feature to join hemisphere to cylinder) what if you Thicken the flat faces enough to intersect the cylinder?
Message 14 of 15
psarkar70
Hello Dr Mather
Thanks for the information. It never struck to me to have a full revolution, it's working now. Thanks for the document it will help me immensely, as I am a beginner and want to know the basics.
Thanks again.
Partha Edited by: psarkar70 on Nov 10, 2009 2:31 PM
Message 15 of 15
SBix26
The workplane was created by selecting the XZ plane and the line in Sketch1. That gives a plane perpendicular to XZ and through the line. That allows the sketch to completely control the angle and radial position of the workplane.
Sam
