I tried to creat this in AutoCAD but extruding multiple circle to follow a path. I also imported the drawing in 3ds max which i have never played with but own. Would this be more of an inventor project?? What would be the best way to tackle this??
I would start by spending about 6 mths learning to use whatever program you want to create the model in.
It is not a beginner project.
Once you have the basics understood,
I would start by laying out the art on sketch planes.
You might be better off creating this in a surface modeling program then importing it to inventor to do mold flow.
Looks pretty easy to do in Inventor to me.
Yes, Ray. You only need to be a perfect FF guy.
I'm waiting for first results.
Walter
Walter Holzwarth
Well, I ain't perfect, but this is close. I haven't done anything with freeform before except maybe the tutorial. Learning curve should be fairly quick. I'm sure with effort I could do better.
I havent play with inventor in years. Mostly AutoCAD and Revit. I just needed a refresher. I will try this approach and let you know.
Thanks again!!
