I am creating my first very simple gears for learning dynamic analysis. I followed a youtube video to create two gears, then I try to run the analysis. When I create a cylinder-to-cylinder joint, it asks for the cylinders (which are the gears) and the origins of those gears. I can set the gears easily, but I cannot set the origins. Please help. I attached the assembly file here.
One more thing, my final goal is to create a pawn and ratchet gear pair and do analysis on the material when there is IMPACT (Suddenly brake) by the stopping of pawn. If anyone have information for that, please provide to me too.
An assembly without parts is useless. Might be useful to go through the basic tutorials before moving on to DS.
The pitch circles can be used to extrude cylindrical surfaces (if not already in the part).
Use these cylinders for the joints and the end circles for the origins.
You might search Amazon for book by Wasim Younis and also there are a couple of built in Tutorials in Inventor, one of which I think uses gears (even though the mechanism is pure garbage).
I don't think you will be able to analyze impact forces in Inventor.
Thanks for your reply. Since I am new to Inventor, would you please give me a clear guide.
"An assembly without parts is useless."
You say my assembly has no part. Do you mean that you see two gears but no other component? Do you mean I need to mount them on shafts before running any analysis?
I use Inventor design accelerator, (to my very limited knowledge) which is only avaialbe in the assembly enviorment, to create those two gears. The gears do not have any shaft holes. If so, how I can create those holes to mount?
"The pitch circles can be used to extrude cylindrical surfaces (if not already in the part)."
When I use the design accelerator, it asked for the gear face width. I put it as 1". Did I do it wrong?
"Use these cylinders for the joints and the end circles for the origins."
I set compinent1>cylinder1 as face of gear1 and compinent2>cylinder2 as face of gear2. What do you mean of end circles for the origins?Do you mean set the end of gears tooth as origins? I tried but do not work
An assembly file (*.iam) is simply a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints.
I recommend you go through the built in Help>Learning Tools>Tutorials.
What book are you using to learn Inventor? (Inventor is a professional program and deserves (requires?) a professional level of preparation. Dynamic Simulation is an advanced topic within Inventor and deserves (requires?) a couple of years of basic experience before moving on to advanced topic.)
More here
http://inventortrenches.blogspot.com/p/inventor-tutorials.html
and here
and here
and search for Wasim Younis book here http://www.amazon.com
