Inventor Forum
How to do a smooth tranistion between two parts
15 REPLIES 15
Message 1 of 16
760 Views, 15 Replies
I need to do a smooth transtition between that first long cube and the cylinder kind of shpe on it's right so that the cube and cylinder are attached toether and we dont see the edges of the cube.
15 REPLIES 15
Message 2 of 16
JDMather
Sketch1, 2, 3, 9, 11, 15, 16 are not constrained.
Workplanes 1, 2 & 3 are not needed.
I recommend you read this while I (or someone) works up a solution.
http://home.pct.edu/~jmather/skillsusa%20university.pdf
What version of Inventor did you say you are using?
Message 3 of 16
EScales
You mean like this?
Message 4 of 16
in reply to: EScales
Yes like that, have you figured it out, is so please tell me the steps
Message 5 of 16
in reply to: JDMather
2010 btw see the other guys pic, that's what i mean. And yeah i know i have bunch of unneed stuff cuz im new to this so i have been experimnting stuff.
Message 6 of 16
EScales
What version of Inventor are you using?
Message 7 of 16
2010
Message 8 of 16
EScales
I created a Loft between a sketch on the end of the rectangular solid and the existing sketch of the cylinder.
Message 9 of 16
Thanks, i have another question though. If you go to the left view you will see the top pipe coming in at a 45 angle from top in the cube. Is there a way to cut it so it's long enough just to get in the cube and not have extra part like there is right now.
Message 10 of 16
GSE_Dan_A
When you extrude the pipe use the TO command.  Then select the cube face. This will extend your tube to the face of the cube without having additional material.
GSE Consultants Inc.
Windsor, ON. Canada
Message 11 of 16
in reply to: GSE_Dan_A
Where is the TO command?
Message 12 of 16
GSE_Dan_A
Windsor, ON. Canada
Message 13 of 16
Curtis_Waguespack
Hi treasure1100,
In addition to the previous replies, attached is a quick approximation of your part that might help. Without knowing the intent of your design I can't say for sure that what I have is correct, but it might serve as an example for you to work through some issues that I foresee you running into.
I hope this helps.
Curtis
Message 14 of 16
swhite
The correct way. Any other solution without the rails will not give you the proper shape in this situation. If you loft without rails you will find your shape is really not smooth, but dips in or out.
For example, this loft looks smooth, but in reality is not.
Another acceptable solution, just depends on the final shape you need.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 15 of 16
EScales
Here's the loft as a sheet metal part, which will give you the flat pattern.
Message 16 of 16
swhite
Good tip Eric, forgot about the sheet metal loft which calculates the rails automatically, but wasnt for sure if he wanted a solid part or duct type part, so gave him the basics.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
