I am trying to display my dimension units in inches but I am having difficulty displaying the (") symbol after the number. e.g. 24" instead of 24 in.
I have my units set to in. and if I check the "unit string" box under Display it only shows (in) after the dimension number. I am using inventor 2013, thanks for any help in advance.
Solved by Curtis_Waguespack. Go to Solution.
Drawing environment or part sketch environment - more information needed.
Attach file here that exhibits this behavior.
Hello.
If you are talking about IDW environment, you can set the Units to ft intead in in. Only in this units you get the " simbol
Hi hawkinsCadGuy,
In addition to the previous replies, there are two ways that come to mind. You might want to look into both to see which works best for you:
I hope this helps.
Curtis
Here is a thread that might speak to what you are talking about. If not, like JD said, we would need more information.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thank you all for your help. It was in IDW environment but I used the suffix trick Curtis suggested and that solved my issue, thank you Curtis.
This will only work on the Dimension tool. It will not work for the Hole and Thread tool.
Hi, You may change notes and leaders by adding " on every item.
like thru hole was: Ø<HDIA> THRU
you can add " to it (Ø<HDIA>" THRU)
Regards
