Inventor General Discussion
Product Support
Daniela_Koloszko
Message 1 of 22 (5,509 Views)
How to disable reflections and gradients in shaded views
5509 Views, 21 Replies
09-14-2010 01:43 AM
You would like to have an option to disable reflections in the shaded views that you create.
Answer
We introduced from Inventor 2010 support for disabling reflections in drawings. In order to do this, users need to add DWORD registry key named "Suppress Specular Color" with value greater than zero under the following registry key.
Note:
Prior to creating this registry key, you need to have the following hotfix installed for Inventor 2010:
http://usa.autodesk.com/getdoc/id=DL15338178
For Inventor 2011, you need to have SP1 installed.
Open the system registry and locate the following registry keys listed below (Start > Run > RegEdit):
1. Inventor 2010
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion14.0\Applets\DrawingLayout\Preferences\]
Create a key with this value:
"Suppress Specular Color"=dword:00000001
2. Inventor 2011
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion15.0\Applets\DrawingLayout\Preferences\]
If the key is not present or its value is zero or less, then reflections are enabled under drawings (Default behavior).
Note: The key is read only once per Inventor session -  after adding the key or changing its value,  users need to restart the Inventor session.
Please find attached as well the registry files for both Inventor versions. By double clicking the appropriate registry file, you can automatically create in your registry the key, as explained above.
Daniela Koloszko
EXCELLENT!!!!!!!
Works perfect on 2011 Sp1...
Just in time too. I'm about to create hundreds of shaded IDW files for all our new products. I hated the reflections.
Thank you Autodesk. (and Daniela)
mcgyvr
Message 2 of 22 (5,484 Views)
Re: How to disable reflections and gradients in shaded views
09-14-2010 05:53 AM in reply to: Daniela_Koloszko
EXCELLENT!!!!!!!
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
DRudaz
Message 3 of 22 (4,941 Views)
Re : How to disable reflections and gradients in shaded views
09-07-2011 01:28 AM in reply to: Daniela_Koloszko
And for the 2012 versions ?
Regards
Dom
Product Support
Daniela_Koloszko
Message 4 of 22 (4,929 Views)
09-07-2011 03:14 AM in reply to: DRudaz
The solution for Inventor 2012 is the same:
[HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion16.0\Applets\DrawingLayout\Preferences\]
Daniela Koloszko
Valued Contributor
DRudaz
Message 5 of 22 (4,926 Views)
09-07-2011 03:22 AM in reply to: Daniela_Koloszko
Hi Daniela,
I'm happy to read you.
But I have tried this registry key, but there is no effect.
Regards
Dom
Valued Contributor
DRudaz
Message 6 of 22 (4,910 Views)
09-07-2011 05:37 AM in reply to: DRudaz
Just a screenshot. I have made test on inventor 2011 SP1 and the result is the same with Inventot 2012 SP1.
Dom
Product Support
Daniela_Koloszko
Message 7 of 22 (4,873 Views)
09-07-2011 07:02 AM in reply to: DRudaz
I did a test in Inventor 2012 SP1 and it works. Please see attached images and also the registry fix which I have added for your convenience. You just need to double click it in your machine and the registry key will be automatically created for version 2012.
Daniela Koloszko
Valued Contributor
DRudaz
Message 8 of 22 (4,851 Views)
09-07-2011 07:41 AM in reply to: Daniela_Koloszko
Maybe is another problem. I send you my part and drawing.
For information I have a French version.
bscioscia
Message 9 of 22 (4,462 Views)
04-27-2012 06:36 AM in reply to: Daniela_Koloszko
I've tried this several times with no luck on 2012.  I've attached a screen shot of my registry files.
Brian
Product Support
Daniela_Koloszko
Message 10 of 22 (4,425 Views)
04-27-2012 08:02 AM in reply to: bscioscia
Could you attach an example, a part and drawing with reflection?
Daniela Koloszko
