Inventor General Discussion
Distinguished Contributor
zdhrichard
Message 1 of 20 (1,070 Views)
How to delete suppressed components by iLogic Rule
1070 Views, 19 Replies
01-24-2013 06:21 AM
I have an assembly which includes lot of parts (*.ipt) or sub-assembly (*.iam).
I have some ilogic rules to control to suppress or unsuppress them.
Now for the released assembly, I want delete all suppressed components by ilogic rule.
Could anybody help me the ilogic code to get this function?
Rich
Autodesk Inventor Professional 2014 (64 Bit Edition)
Build: 246, Release 2014 SP2 Update 2
Windows 7 Professional Service Pack 1
Intel(R) Xeon(R) CPU E5645
12.0 GB Memory
Dim oComp As ComponentOccurrence
Dim oComps As ComponentOccurrences
oComps = ThisDoc.Document.ComponentDefinition.Occurrences
For Each oComp In oComps
If Component.IsActive(oComp.Name) = False Then oComp.Delete
Next
Try adding this to the end of your DeleteFeatures sub:
Dim oSketch As PlanarSketch
Dim oSketches As PlanarSketches
oSketches = oDoc.ComponentDefinition.Sketches
For Each oSketch In oSketches
If oSketch.Dependents.Count = 0 Then oSketch.Delete
Next
Next
The reason the first code doesn't clean up all of the sketches is because it only deletes those sketches that are being consumed by the features that are being deleted.
Note that we have to run though all of your skecthes twice. This is because you have interdependencies between sketches and you cannot delete a sketch that has something else dependent on it. I'm playing around with a more elegant way to do this, but this way does work.
mrattray
Message 2 of 20 (1,061 Views)
Re: How to delete suppressed components by iLogic Rule
01-24-2013 07:26 AM in reply to: zdhrichard
Next
Mike (not Matt) Rattray
waynehelley
Message 3 of 20 (1,057 Views)
01-24-2013 07:44 AM in reply to: mrattray
Hi Mike, by any chance do you know how to do the same but for deleting suppressed features in the part environment?
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2013
Windows 7 Enterprise, 64-bit
mrattray
Message 4 of 20 (1,054 Views)
01-24-2013 07:58 AM in reply to: waynehelley
Dim oFeature As PartFeature
Dim oFeatures As PartFeatures
oFeatures = ThisDoc.Document.ComponentDefinition.Features
For Each oFeature In oFeatures
	If Feature.IsActive(oFeature.Name) = False Then oFeature.Delete
Next
zdhrichard
Message 5 of 20 (1,041 Views)
01-24-2013 10:48 AM in reply to: mrattray
Thanks lot, Mike.
Rich
12.0 GB Memory
zdhrichard
Message 6 of 20 (1,039 Views)
01-24-2013 10:54 AM in reply to: mrattray
Hello MIke,
For deleting features, do you know how to delete the relative sketches?
I tested the codes, it could delete features, but the sketches are still in the tree.
Rich
12.0 GB Memory
mrattray
Message 7 of 20 (1,033 Views)
01-24-2013 11:00 AM in reply to: zdhrichard
When I tested it the code deleted the consumed sketches as well as the feature. Can you attach the model?
zdhrichard
Message 8 of 20 (1,029 Views)
01-24-2013 11:23 AM in reply to: mrattray
Here is a simplified model.
Rich
12.0 GB Memory
mrattray
Message 9 of 20 (1,025 Views)
01-24-2013 11:31 AM in reply to: zdhrichard
Did you already run your delete features sub on this part? The code doesn't do anything at all for me.
zdhrichard
Message 10 of 20 (1,020 Views)
01-24-2013 11:43 AM in reply to: mrattray
Yes, I did. This is the result after runing the code.
Rich
12.0 GB Memory
