hi dear sir/Buddy.................
A solution u did give earlier to some helped me alot what i wanna achive , Imade some chages according my need
and its working but i wanna little more help from u please...... attaching file
Auto = iLogicVb.Automation
Dim iLogicAuto As Object
iLogicAuto = Auto
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'Master file name
If Not (ThisDoc.FileName) = "iLogic" Then
Dim ruleName As String
Dim rules As Object
rules = iLogicAuto.rules(oDoc)
'Remove rules
If Not (rules Is Nothing) Then
For Each rule In rules
ruleName = rule.Name
iLogicAuto.DeleteRule(oDoc, ruleName)
Next
Else
i = MessageBox.Show("No Rules are in File")
Dim oFeatures As PartFeatures
oFeatures = oDoc.ComponentDefinition.Features
Dim oFeature As PartFeature
'Remove suppressed features
For Each oFeature In oFeatures
featureName = oFeature.Name
i = MessageBox.Show("Click Yes to delete all Fetures or No to Suppressed or Cancel to abort", "My iLogic Dialog", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
' If Not Feature.IsActive(featureName) Then
If i=vbYes Then
i = MessageBox.Show("Deleting All Features ")
oFeature.Delete
Else If i=vbNo Then
' i = MessageBox.Show("Deleting Supressed Features ")
oFeature.Delete
Else
i = MessageBox.Show("Action canceled ")
Next
'but now something more i wanna do is...... delete parameters
If Not (param Is Nothing) Then
For Each param In params
i = MessageBox.Show("Checking for Parameter in File")
i = MessageBox.Show("No.of Parameters exists are ="& param.count)
paramname=param.Name
On Error Resume Next
param.delete(oDoc, paramName)
paramName =ThisDoc.Document.ComponentDefinition.Parameters
iLogicAuto.Deleteparam(oDoc, paramName)
Next
Else
i = MessageBox.Show("No Parameter are in File")
Thanks to all
still while you didn't help me
its ok
some how i found it it code to delete all unUsed parameters is........
Public Sub Main() 'ModelParameters()
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters
Dim oPartDoc As Inventor.PartDocument ' Obtain the active document, this assumes ' that a part document is active in Inventor.
oPartDoc = ThisApplication.ActiveDocument
Dim oParams As Parameters ' Obtain the Parameters collection
oParams = oPartDoc.ComponentDefinition.Parameters
i = MessageBox.Show("You wanna delete all Unused Parameters", "My iLogic Dialog", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
If i=vbyees Then
Dim iNumParams As Long ' Iterate through the Parameters collection to obtain ' information about the Parameters
For iNumParams = oParams.Count To 1 Step -1
oParameter=oMyParameter(oParams.Item(iNumParams).Name).delete
Next iNumParams
End Sub
I have this code its working
but need some work to be sharp
any help will be very thankful
Sub Main()
p = InputListBox("Choose to Delete", New String(){"None","All Rules","Features", _
"All unUsed Parameters","Everything in List"}, New String(){"None","All Rules","Features", _
"All unUsed Parameters","Everything in List"}, Title := "Chose to delete", ListName := "List")
Select Case p
Case "None"
'do nothing
Case "All Rules"
deleteRules()
Case "Features"
deleteFeatures()
Case "All unUsed Parameters"
deleteParameters()
Case "Everything in List"
deleteRules()
deleteFeatures()
deleteParameters()
End Select
End Sub
Sub deleteRules()
iLogicAuto = Auto
'Master file name
Dim rules As Object
'Remove rules
Next
Else
End Sub
Sub deleteFeatures()
iLogicAuto = Auto
'Remove features
p = InputListBox("Choose to Delete", New String(){"None","All Features","Suppressed Features"} _
,New String(){"None","All Features","Suppressed Features"} , Title := "Chose to delete", ListName := "List")
If p="All Features" Then
oFeature.Delete
Else If p="Suppressed Features" Then
oFeature.Delete
Else
Next
End Sub
Sub deleteParameters()
If i=vbyees Then
Next iNumParams
End Sub
