I'm still new using autodesk inventor and still learning. I have trouble to cut the plate (Penahan Depan.ipt) follow the radius of the roll (Roll.ipt) Please give me the solution.. Thank you..
I'd create a sketch bisecting the Penahan Depan part vertically. Project the edges of the Roll onto the sketch and cut the Penahan Depan part via the revolve command.
sorry i mean not Penahan Depan.ipt but penutup depan.ipt
Do a Revolve Cut at the part level
or
edit the part at the assembly level and Copy Object as surface body the faces of the Roll to use for cutting and then Sculpt or Split. (this will cut exactly same size and associative - but no allowance for tolerance and motion, you will need to consider that as well)
