This pipe is made to connect 2 pipes.The 2 pipes are at different heights.The difference in height is 21.5°.When i create this pipe attached it has a slope on one end instead of a straight edge like the other end.Would this be due to me using the wrong technique to create this pipe?
Sam
2014 .ipt attached
Solved by JDMather. Go to Solution.
Your profile was not perpendicular to the path.
See attached for an easier technique.
Here is another example that does not require a 3D sketch.
