Inventor Forum
How to create sketch on a sphere?
10 REPLIES 10
Message 1 of 11
Nate711
10724 Views, 10 Replies
I am trying to make a sketch on a sphere so I can extrude it. How can I make a plane or something on the sphere? The point where I would like to make the feature is not on a X or Y or Z plane. (Imagine the 90 degree lines on a globe and its not on there). Does anyone have a solution?
Edit: I want to make the extruded feature go normal to the surface.
Nate
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: Nate711
Split face and thicken.
What are you trying to design?
Attach your file here of what you have completed so far or a picture of something similar.
Message 3 of 11
PaulMunford
You can treat creating a plane perpendicular to a sphere in the same way as a cylindar.
You can use:
  • Work axis > Point > Plane
  • Sketch > Point > Plane
  • sketch point > Plane.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Tags (2)
Message 4 of 11
Dennis_Jeffrey
Workplanes, workplanes, workplanes.
In my classes, I spend a lot of time teaching workplanes. Without the ability to place a workplane at any position you need, you are stuck with modeling primitive forms.
Here's your answer....
http://teknigroup.com/Videos/2012Q2/WP-Sphere-angled/WP-Sphere-angled.html
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 5 of 11
answer was removed
Message 6 of 11
Dennis Jeffrey died in 2011. Teknigroup doesn't exist anymore.
What do you want to know in this matter (Sketch on sphere) ?
Walter Holzwarth
Message 7 of 11
johnsonshiue
in reply to: WHolzwarth
Hi Andrew,
Starting from Inventor 2017, 3D Sketch has been enhanced to have Curve on Face. You can directly sketch on a sphere or any face.
Many thanks!
Software Test Engineer
Message 8 of 11
Uh, was I on the wrong forum or are you saying that the same is possible in
Fusion 360?
Message 9 of 11
Hi Andrew,
Inventor and Fusion 360 are two different products. Which one are you using? Curve on Face is available on Inventor 2017 and later. I am not sure if it is available on Fusion 360. I am an expert on Inventor and I know very little about Fusion 360.
Many thanks!
Message 10 of 11
Okay, I figured out a solution. But since you're an expert at inventor.
Is it a good program for hard surface modeling for animation films to be
used with 3D max, a UV program, and substance painter. Fusion works
wonderfully with these programs but if Inventor is better...
I just don't want to have to learn another program just to see if it's
better than what I'm using. Thanks.
Message 11 of 11
Hi Andrew,
If Fusion works for you, you should keep using it. There is no reason to switch to anything. It is like Inventor users. They are using Inventor to design various industrial models. These tools are different options for you to choose. Depending on the work you do, you may prefer one over another.
I don't know what you are trying to do. But, I am sure there are Inventor users working on similar projects. If you can show more detail, the forum experts can comment further.
Many thanks!
