I have a part that will be put in Factory Library. The part itself consist of number of slots that is controlled by a key parameter (NoOfConveyors) and the connectors should be located in the middle of those slots. Is there anyway to make the that same NoOfConveyors key parameter translate to the number of connectors? What would be the iLogic command that control the number of connectors in a part?
Below, I attached the screenshot of the part in question.
Thank you,
Harris
