I am trying to create a new custom property for drawing sheets. the custom property is to show the value of the scale for the particular sheet. I was able to create a custom scale property for the drawing, it works, but the value that I enter will show the same in all sheets created for that drawing, I need to be able to create a custom property that is specific to each individual sheet.
Hi Josnastasi,
As iProperties are defined at drawing level, you can create in the drawing a set of custom iproperties like:
ScaleSheet1
ScaleSheet2
ScaleSheetn
In those properties you can store the scale for each sheet.
Then you could relate scale value on each sheet to the corresponding iProperty.
Best regards
