I have 2 hose ends in an assembly.Cannot figure out how to create the rubber hose with a realistic look.Can someone show me how to create the hose which has curves/bends for a natural look?
Inventor 2013
Solved by Cadmanto. Go to Solution.
James,
I would look into using flexible hose in the Tube and Pipe command. Have you used tube and pipe before?
Within the T & P commands is a hose style that might fit what you are looking for. If not within the T & P styles editor you can copy an existing style that is close and tweak it to be wqhat you want.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You're welcome. Hope it works out for you. If you have any other issues let us know.
