Inventor Forum
How to create flat pattern of attached part
3 REPLIES 3
317 Views, 3 Replies
Dear all,
Is there any way to create flat pattern of a part I attached ?
Thank you!
3 REPLIES 3
CCarreiras
HI!
No, it will not flat because this isn't a bend, but a plastic deformation and inventor it will not compute this kinds of deformation.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
CCarreiras
in reply to: CCarreiras
Hi!
Try to do it approximately, design a new part with arcs (Without 3D sketches), and in the final, the difference will not be far from the real part (in most of the cases).
CCarreiras
Thank you very much.
I found out that such parts can be createt if they are symmetric to at least one axis (then you can use "Countour Roll").
Can anyone tell me what steps must be done to convert standard part to sheet metal ? (I haven't figured out this one yet 🙂 )
