Inventor Forum
How to create Barb Wire
5 REPLIES 5
Calavetta123
6410 Views, 5 Replies
I need to make a coiled barb wire around a 360 degree pipe with a 6" diameter. I am not sure what the easist way to accomplish this would be. Is there anyway to create an arch axis. I would like to create a coil around an arch axis not a straight axis.
Robert
IV 2024 Pro-Suite / VP 2024
5 REPLIES 5
JDMather
in reply to: Calavetta123
Sounds like Coil.
Circular pattern for twisted pair.
Barb
"Rectangular" Pattern for curve driven pattern of barbs.
Bend Part.
Can you attach what you have attempted so far?
jeanchile
I think more importantly... what are your plans this weekend and where are you taking this thing when it's built (so I can stay away):smileywink:.
Inventor Professional
Calavetta123
in reply to: jeanchile
I found this link that help me out on exactly what I was trying to do. Check it out if interested.
http://forums.autodesk.com/t5/Autodesk-Inventor/coil/m-p/2605079
JDMather
You are doing too much work and that doesn't look like your problem description.
A simple Coil and Bend Part would have resulted in the same geometry.
