Inventor Forum
How to create Barb Wire
5 REPLIES 5
Calavetta123
6405 Views, 5 Replies
I need to make a coiled barb wire around a 360 degree pipe with a 6" diameter. I am not sure what the easist way to accomplish this would be. Is there anyway to create an arch axis. I would like to create a coil around an arch axis not a straight axis.
Robert
IV 2024 Pro-Suite / VP 2024
5 REPLIES 5
JDMather
in reply to: Calavetta123
Sounds like Coil.
Circular pattern for twisted pair.
Barb
"Rectangular" Pattern for curve driven pattern of barbs.
Bend Part.
Can you attach what you have attempted so far?
BMiller63
jeanchile
I think more importantly... what are your plans this weekend and where are you taking this thing when it's built (so I can stay away):smileywink:.
Inventor Professional
Calavetta123
in reply to: jeanchile
I found this link that help me out on exactly what I was trying to do. Check it out if interested.
http://forums.autodesk.com/t5/Autodesk-Inventor/coil/m-p/2605079
JDMather
You are doing too much work and that doesn't look like your problem description.
A simple Coil and Bend Part would have resulted in the same geometry.
