A plane by definition is a flat surface, I don't see how you could make it around the
circumference. If you start the plane command and hit F1, you should be presented with
some pretty good guides to methods of placing planes.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Willie" wrote in message news:4032382f_3@newsprd01...
> Thanks to both of you for your input.
> Originally I was thinking it would be nice to create a plane around the
> entire circumference of my cylinder but I can see that probably is not a
> good idea.
> Thanks again and have a great day!
