Inventor Forum
How to create a spiral in Inventor with a variable pitch
2 REPLIES 2
jwillieinventor
586 Views, 2 Replies
Hello All,
I am having difficulties creating a spiral with vairable pitch using sweeping or the coil function in inventor. I am told that the Equation Curve option works but i do not know the equation for this spiral. What I have is the the length/height of each segment that makes up the spiral and the pitch of the spiral. In addition, i have the profile coordinates in (x,y) in excel.
Does anyone know how I can go about this?
Thanks!
Jimmy
2 REPLIES 2
Hi!
Place the files and we will give it a try...
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
This might help.
http://cadprosystems.blogspot.com.au/2011/11/variable-pitch-auger-creation.html
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
