I want to draw hyperbola curve whose equation is x^2/a^2 - y^2/b^2=1. May I use equation curve tool to make the above hyperbola. If it is possible please help me to do so.
I have also made a hyperbola curve of aforesaid equation through conventional method on mathematical ground in the past. I am posting the file of the same to make the question clearer.
Regards
SORJM
Solved by karthur1. Go to Solution.
First thing, write your equation in terms of Y=SQRT(b^2((x/a)^2-1)). For the equation curve, set x=t
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013
Here is another example of an hyperbola with these parameters.
Center (420 , 0) mm
a = 300mm
b = 80mm
So the equation is:
((x-420)/ 300)^2 - (y/80)^2 = 1
x(t) =t
y(t)=sqrt(( ( ( ( t - 420 ul ) / 300 ul ) ) ^ 2 ul - 1 ul ) * ( ( 80 ul ) ^ 2 ul ))
See attached part
Is it possible to draw a hyperbola curve from a sheet of metal by the given values?
a=1.9
b=1.46
c=2.4
and the following equation is x2/a2 – y2/b2 = 1
Amjad
Center (420 , 0) mm
a = 300mm
b = 80mm
So the equation is:
x(t) =t
See attached part
Your equation is in the form X^2-Y^2=1 (X^2/a^2) = (X/a)^2.... which is like the example in message 5 I posted.
If you still cant get it, post your ipt and I will see what I can do.
Here is the equation for what you asked for. a=1.9, b=1.46
Not sure where to put the "C" value you gave.
Here is the results after I mirrored the initial curve a couple times. See attached file (Inv Version 2018)
Since the equation that I worked out if for a vertical hyperbola, I had to rotate the axis for your problem. To do that, I had to change some things around
Where a=1.90 and b=1.46, I then have this for the equation curve.
See attached file of the part.
