Inventor General Discussion
Valued Contributor
SORJM
Message 1 of 3 (1,855 Views)
How to create a Hyperbola curve using Equation Curve (Autodesk Inventor 2013)
1855 Views, 2 Replies
02-19-2013 10:34 PM
I want to draw hyperbola curve whose equation is  x^2/a^2  - y^2/b^2=1. May I use equation curve tool to make the above hyperbola.  If it is possible please help me to do so.
I have also made a hyperbola curve of aforesaid equation through conventional method on mathematical ground in the past. I am posting the file of the same to make the question clearer.
Regards
SORJM
First thing, write your equation in terms of Y=SQRT(b^2((x/a)^2-1)). For the equation curve, set x=t
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013
karthur1
Message 2 of 3 (1,825 Views)
Re: How to create a Hyperbola curve using Equation Curve (Autodesk Inventor 2013
02-20-2013 06:01 AM in reply to: SORJM
Kirk A.
Vault Basic 2013
Valued Contributor
SORJM
Message 3 of 3 (1,815 Views)
02-20-2013 08:26 AM in reply to: karthur1
Thanks for the quick and valuable response. It shows your excellent command over the software.
Regards
SORJM
