Inventor Forum
How to create a Hyperbola curve using Equation Curve (Autodesk Inventor 2013)
8 REPLIES 8
Message 1 of 9
SORJM
4898 Views, 8 Replies
I want to draw hyperbola curve whose equation is  x^2/a^2  - y^2/b^2=1. May I use equation curve tool to make the above hyperbola.  If it is possible please help me to do so.
I have also made a hyperbola curve of aforesaid equation through conventional method on mathematical ground in the past. I am posting the file of the same to make the question clearer.
Regards
SORJM
8 REPLIES 8
Message 2 of 9
karthur1
in reply to: SORJM
First thing, write your equation in terms of Y=SQRT(b^2((x/a)^2-1)). For the equation curve, set x=t
Kirk A.
Windows 7 x64 -12 GB Ram
Intel i7-930 @ 3.60ghz
nVidia GTS 250 -1GB (Driver 301.42)
INV Pro R2013, SP1.1 (update1)
Vault Basic 2013
Message 3 of 9
SORJM
in reply to: karthur1
Thanks for the quick and valuable response. It shows your excellent command over the software.
Regards
SORJM
Message 4 of 9
karthur1
Here is another example of an hyperbola with these parameters.
Center  (420 , 0) mm
 a = 300mm
 b = 80mm
So the equation is:
((x-420)/ 300)^2 - (y/80)^2 = 1
x(t) =t
y(t)=sqrt(( ( ( ( t - 420 ul ) / 300 ul ) ) ^ 2 ul - 1 ul ) * ( ( 80 ul ) ^ 2 ul ))
See attached part
Message 5 of 9
Is it possible to draw a hyperbola curve from a sheet of metal by the given values?
a=1.9
b=1.46
c=2.4
 and the following equation is x2/a2 – y2/b2 = 1
Amjad
Center  (420 , 0) mm
 a = 300mm
 b = 80mm
So the equation is:
x(t) =t
See attached part
Message 6 of 9
karthur1
Your equation is in the form X^2-Y^2=1    (X^2/a^2) = (X/a)^2.... which is like the example in message 5 I posted.
If you still cant get it, post your ipt and I will see what I can do.
Message 7 of 9
Message 8 of 9
karthur1
Here is the equation for what you asked for. a=1.9, b=1.46
Not sure where to put the "C" value you gave.
Here is the results after I mirrored the initial curve a couple times.  See attached file (Inv Version 2018)
Message 9 of 9
karthur1
Since the equation that I worked out if for a vertical hyperbola, I had to rotate the axis for your problem.  To do that, I had to change some things around
Where a=1.90 and b=1.46, I then have this for the equation curve.
See attached file of the part.
