Inventor Forum
How to create a curved ramp?
10 REPLIES 10
Message 1 of 11
ruieduardonunes
5735 Views, 10 Replies
I'm trying to build a curved ramp aroun an axis on inventor pro 2015. I tried to draw a 3d sketch of the curve and then project it to surface. Then I tried to revolve with the path being the projected line but I had no results. What is the better way to do this.
Thanks in advance for your help.
10 REPLIES 10
Message 2 of 11
JDMather
in reply to: ruieduardonunes
Is the curve a helix?
Use the Coil command.
Attach your attempt here.
Message 3 of 11
ruieduardonunes
in reply to: JDMather
I attached the file as you asked. The objective was to make a 180º curved ramp. In the file you will find my atempt. I was not able to make it grow any further.
Regards.
Message 4 of 11
JDMather
I got lost on the first sketch.
Can you explain where the dimension for the 2mm circles comes from (see attached)?
Message 5 of 11
ruieduardonunes
I already managed to do the total ramp but with stairs. I wanted this ramp to be smooth. I attached the file.
Thanks for the help.
Best regards.
Message 6 of 11
JDMather
I am having great difficulty understanding your design intent - but maybe something like attached?
Message 7 of 11
ruieduardonunes
Where i have the steps in the previous attachment i would like to have something like this http://archicad-talk.graphisoft.com/files/thumbs/t_roofs_curved_ramp_15_208.jpg.
Regards.
Message 8 of 11
JDMather
Isn't that what I attached?
Message 9 of 11
johnsonshiue
Hi! I played around with it for a few minutes and came up with this solution using Rect Pattern along Helical Path workflow. Please take a look and see if it works for you.
Thanks!
Software Test Engineer
Message 10 of 11
ruieduardonunes
Yes, I'm sorry. I haven't seen the attachment.
Thanks for your help and time. I will now study your process.
Best Regards.
Message 11 of 11
Hi.
I had already done something like you describe here. But the objective was to get a smooth ramp. The previous comment answered my question.
Best regards.
