i have an existing frame design by Inventor but then i wish to copy out the existing design and modify it !
so i try with the copy function in design assistant but then i found that after i modified the frame size or profile in the copied frame design, the existing frame design changed as well!
how to break the link between these two frame design on this case?
Solved by Curtis_Waguespack. Go to Solution.
Hi weiloon,
You might try the add-in mentioned at this link:
I hope this helps.
Curtis
hi,
i tried the plug in clone and its great!
but i do have a problem with it. i copied the idw too aside from the parts but the idw has titileblock that links the part number in the iproperties of the ipt/asm and shows as the titleblock name.
eg. aaaa.idw = bbbb.idw file (after cloning) but the titleblock still shows aaaa. i open the cloned file bbbb.ipt and saw inside iproperties, the title and part number in iproperties still has the old name.
how to correct this ? i cant change it manually as parts is by the hundreds.
inventor 2011
vault 2012
I still go for Vault Copy Design.... assuming you have Vault.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
