Inventor Forum
How to copy and paste sketch in same plane
3 REPLIES 3
linuskotte
1400 Views, 3 Replies
Hi all
I have big problem
i have a one rectangular block(Control cabinet) it consists of around 100 sub rectangular blocks here problem is in my part user wants few blocks in different dimensions and different positions some time. So I created one sketch in my sketch plane then user wants more features on rectangular block then I want automatically copy and paste on same plane same sketch and same time automatically asking for dimensions(positional, length and width).
It's possible?
Thanks in advance..
Thanks and Regards
LINUS KOTTE
3 REPLIES 3
Mark_Wigan
in reply to: linuskotte
hi,
i am not 100% sure i understand but if i am right & depending on where you are up to in your design process it may not be a big problem.
- if you want it to prompt you for sizes then you can setup an iFeature or iPart depending on what you need at the end of the day.
so if you have already drawn your good shape, you can export that as an iFeature and just add it as many times as you like in any of the drawings that you or your fellow designers are working in.
see the help and how to training resources in inventor for more info, or if you need a bit more support please ask after you have had a look at the topic a little bit.
best regards,
- Mark
(Kudo or Tag if helpful - in case it also helps others)
PDSU 2020 Windows 10, 64bit.
JDMather
Can you post screen shot?
linuskotte
in reply to: JDMather
Hi all
Here I attached my model view it's just for reference here iam using rectangular pattern and simple ilogic code .Using rectangular pattern we will get all same sizes of boxes but i want to change different different sizes and positions. my idea is without using pattern just draw one rectangular through parameter. Select no. of compartments automatically copy and paste that rectangular in same sketch plane and ask sizes and positions dimensions.
It's possible through ilogic?
In my panel bar options are:
Hight of panel- Hight of panel
width1- Width of panel
Depth1-Depth of panel
com1- no.of Compartments
hIN- No.of Hinges
Please Help me
Thanks in advance
Thanks and Regards
Linus kotte
