Inventor Forum
How to copy a part and place it at a certain location
2 REPLIES 2
hawkinsCadGuy
427 Views, 2 Replies
I am trying to copy a part that is in my assembly drawing and then place multiple instances of that part at equally spaced distance between each other. I can copy the part but i don't know how to place the copied part at the distance i want to place it in. Any help is appriciated, thanks.
2 REPLIES 2
cbenner
in reply to: hawkinsCadGuy
When you say assembly drawing, I assume you mean assembly model?  You copy the part and then place it and control the location with assembly constraints, then you can use a pattern to get the rest.
hawkinsCadGuy
in reply to: cbenner
Problem solved! Thank you for your help
