I am using Inventor Professional 2013, am trying to convert a plenty of files from idw to dwg, Is there any way to make it happen very quick. Note that all the drawings are in vault and have been released.
thanks in advance
Solved by rhasell. Go to Solution.
Solved by mcgyvr. Go to Solution.
Use "task scheduler" located in the autodesk folder in your start menu of windows
Hi
Have a look at a previous post I published here. This will describe the process.
