Inventor Forum
how to convert 3d dwg to ipt
3 REPLIES 3
jacob lu
15549 Views, 3 Replies
What is the procedure or command? thx.
3 REPLIES 3
JDMather
in reply to: jacob lu
Make sure you have the latest Hot Fixes and SP installed.
File Open type AutoCAD DWG
Options>Import
then
run Feature Recognition from http://labs.autodesk.com (optional)
That is the easy way - now the hard way
In AutoCAD acisout
In Inventor File Open *.sat
Even the hard way is easy.
pcrawley
Um - File>Open - set file type to DWG?
Or: Open the DWG in AutoCAD - save it as a STEP file then open it in IV.
If you have Feature Translator plug-in installed, you can create a feature tree too.
Peter
Josh_Petitt
I have also had success with Open, Files of type .dwg.
However, the dwg must have solids, not lines. If it is a 3D solid .dwg, then it should come in fairly easily. Each of the 3D solids will be made into an .ipt and assembled into an assembly.
